soft top
Does any body know the sequence when your electric roof looses its power to allow the hood to go down please
regards
you can open your roof by putting the key in the drivers door to the open position and hold it, this should start to open your roof and windows. Keep the key held in the open position until the roof is fully open.
if your key is programmed to open the roof you can press the unlock button on the fob 3 times and hold it on the third press....... this should start to open your roof. Keep the botton pressed untill the roof is fully opened.
If your keys in the ignition and there is power going to the roof switch you should be able to open your roof regardless of whether your doors are open or closed.
The only things that will stop you from opening your roof is if the car is being driven or if the compartment that the roof folds into in the boot is closed to give you more room in the boot.
