Brake Warning Light Problem.. Help Needed....
10
10
hi Dave, I had a look there and if its there I couldn't find it, the only other place it seems to suggest is to do with the BC button on the indicator lever but I have tried that as well and no joy, it may be that there is some sort of procedure which has to be followed in the right order but until now I am at a loss. cheers Paneuro.
