Overheating, pipes are hard, had water leak - not the water pump, not the thermostat, radiator been flushed. Pipe at bottom left of radiator is cold, all other pipes are hot and pipes very hard. Mechanic cannot find fault, any ideas?
commen prob with BMWs isnt it. im looking into mine to.
take it the headgasket is ok? could be temp sensor, thats what im looking at changing next.
did you mechanic plug a scanner into it?
