Need Opinion
Water leak at sharkfin aerial
7
- bmw 3 series
(and 4 more)
- bmw 3 series
(and 4 more)
7
You are absolutely right. The strange thing is that when I put the chassis number on the realoem it shows that the temp sensor is not applicable on my vehicle. I will physically check for a sensor. In the meantime, do you think that the removal of the MAP activated thermostat will effect the temp gauge on the dial instrument item 6? I am tempted to add a dummy resistor , 11.5ohms - 13watts , to simulate the MAP thermostat. Your thoughts?
