Engine Noises That Make You :-)
2024 x6 six cylinder vs 8 cylinder. Is 8 Cylinder worth it
i am looking to buy a 2024 x6 , is the 8 cylinder worth the extra money -
BMW 116i Hatch F20 2013. Headlight Issue
Hi , Living in Lawrence Otago and need some help. I have some condensation forming in Lefthand headlight. I open the top circular seal and it eventually appears dry. But! Now giving me fault codes on dash display. Like the auto adjust not working and other intermittent faults. Is there anyone nearby that can assist with diagnostic or suggest a 'tame' service centre close to me? I have ordered a control module but thinking about it I would hate to insert the unit when there may be other issues causing the problem and as a consequence stuff up the new module. -
Hi My rear suspension failed last week and I diagnosed the problem to the a 'sticky' main solenoid ( not the two way block) I replaced the solenoid and checked it and the compressor before re- fitting to the car. Guess what/ The compressor doesn't work as there is s no 12v to the compressor The fuses (152 and 182) are fine and the relay works when tested 'on the bench'? Any ideas guys? -
No emergency door lock
Afternoon Frankolinno Welcome to the Forum I would start at the Boot/Trunk look above the number plate for a Key hole, you should have a key blade as part of the Fob Find the Key hole open the Boot/Trunk and you have access to the Battery. If charging the battery remove it from the car to charge it. There should also be an emergency key hole on the underside of the drivers door Good Luck Dave -
Hi my Battery is flat, my fob does not work. Removed caps at the side of the door handles, no emergency keyholes/locks present. I do have the fob keys, but no lock to put them in. BMW 420d 2014 Any ideas how to get in the car? Any help appreciated Thank you
