New To Bmw Ownership
Can someone please enlighten me on how the auto grill system is supposed to work? My 2018 M40i has this system fitted but I don't recall seeing it closed I understood that it closed during cold weather to allow the engine to warm up quicker. -
6
Thank you for your interest in this topic. There is some hope that a solution can be found through joint efforts) I eliminated the oil feed pipes.Since the first thing I did was replace the sealing rings there. I am attaching a few more photos showing the leaking area. -
6
The plot thickens I have changed 2 Turbo's on friends cars but in both cases they were refurbished Turbo's brought as the OEM ones were beyond help. And were fairly straight forward (grazed knuckles) to change. Could the leak you spotted be coming from the Oil Feed pipe ? Dave -
6
Hi Dave, Sure, realoem. Part number (steel gasket) is 11628576287. and according to the second drawing (please see attached), this is the EGR Line Gasket. Andrew -
6
Hi Andrew Are you using www.realoem.com ? The drawing looks like it or is that from the Internet? Is the turbo fitted OEM ? Dave
