Hi Guys,
I’m after a bit of advice here!
I have changed the battery and now all of a sudden i’m getting the “Battery Restraint Malfunction” warning on the dashboard. When I go to clear the code and restart the engine the warning comes straight back on.
Any ideas what to check first?
Thanks in Advance.
Ali
Morning Stu
The fact you have a wiper issue would point me away from the Cluster initially
My thoughts are Footwell Module it's in the left hand footwell (well it would be 😅) Run a scan it should show up any issues. The Footwell control module on the 4.6 caused all sorts of odd stuff radio that would randomly turn on/off odd light issues seat controls. BMW say you can't swap them it has to be new and set up by them (wrong of course) I changed mine for an upgraded unit second hand it took longer to remove the old unit and swap it than it did to re-program it cured everything and probably stuff I hadn't found 😅
P.S I wont let the E70 on Whats App or Face Book just in case 🤣
