Welcome aboard, Crookie...
Yep 265's is some wide footprints !! Thought my 255's would be widest so far Lol
Be careful with the fronts, crookie....
Put what you like on the rears 'cos it's a fixed axle...
The fronts are a different story as you will upset the camber and toe-in/out by using wide wheels 'n tyres...
You will notice excessive scrubbing...
... And most often than not, Tracking and ball joint issues further down the line :unsure:
  • 4 weeks later...
Hi can anyone help how does the gear ##### come off on a e46 ????
Post up in the right section for help mate ;)
I should "Correct" myself...
I think the rear drive is actually a mounted diff with live shafts...
In any case, when fitting wide stuff, you might want to consider whether they would scrub the arches !
