Hi guys and dolls, I have a little issue.... On the centre console there are 2 'soft close flaps' which then excess a compartment, the lower one which has the !Removed! lighter in is broken... The soft close/open doesnt work and this piece in the pic is loose! Does anyone know how to fix it?
Beat me to it, the springs are in the form of metal plates...like in the pic, they should slide back in place..
Sorry luke... But if there is a broken lug then the spring won't work... You could try super-glueing something there...
Easier to just replace it !
EBAY SEARCH....
E36/E46 ashtray / cigar lighter ?
Or, BMW mk3 Ashtray unit....
      Low annual.use.
    2. 27
      A paddling pool in the rear of my 08 reg 635d Convertible !!
    3. 10
      Low Oil Pressure Light on E90
    4. 0
      Dimming Door mirror lenses
    5. 6
      Z3 airbag wiring,
    • Robbo65 earned a badge
    • Dennis R earned a badge
    • bertatronics earned a badge
    • Andrewkuk earned a badge
      Reacting Well
    • David A. Bolden earned a badge
