lads - i'm considering changing from r/flats to standard tyres on my 530/d m sport. i've heard the opinions on both sides and i favour changing. has anyone done this? and with what effect? - however,if i am to do this i will need a 245x40x18 rim -for the spare wheel. if anyone can help email with price to [email protected] i am based in congleton, cheshire soonly within reasonable distance please.
gav- wanted to get more opinions- i think if anyone has spare rim they will still see it on this bit. thanks for your reply mate.
Dexxy,Iv'e just joined this site and I have considered it before but have been told it's not just a straight swap because of the warning system associated with the runflat tyres.Is this true or can you just swap the tyres?many thanks.
I think the warning system detects the car's stance and not the actual tyre... A system that monitors the tyre physically, has its sensors transmitted from the tyre valve/cap !
Dont know if the BMW's the same system, but my Mini detects flats by comparing wheel speed rotation...eg if one flat it will spin faster due to smaller diameter.
If same system, long as all tyres pumped up the same...no probs
Good answer, Gav... But wouldn't the ABS sensors think there was "wheelspin" when one wheel rotates faster?
Different sensors ;)
Yep...
The ABS will apply slight braking to the offending wheel to match the rest.
ALL sensors are Negotiated through the OBC, as you already know...
I cannot see any immediate problem in changing to standard tyre setups, IMHO.
