How easy is it to remove the front indicators? just wondered as ive ordered some new ones with clear lenses and black internals to match the headlights and clean the front up abit.
Cheers.
First... Open the petrol flap, then get an angle-grinder...
Second... Paint the sunroof GREEN and open the bonnet...
Thirdly... Drain all of the coolant and oil, then you will have access to a screw !!!
:lol: :lol: :lol:
TBH I wasn't much help, was I :P
:lol: :lol: :lol:
Done that still can't find screw
Maybe I used the wrong shade of green in sunroof :-)
No you wasnt,but hey.....least its a couple more onto your post count ,lol ;)
Your doing a lot of post count noticing recently mate ;)
Yep, you did.... It HAS to be BRGreen :blink:
If its pre facelift. You need a long screw driver or stick. Look for a hole in the wing inside the engine bay. Stick the screw driver in there to push the clip together then slide it out. Easy as
:lol: :lol: :lol:
:o Mine aint got a sunroof so i've got no chance :P
Cheers guys mines a pre facelift so should be straight forward will get some pics up once i've fitted the new ones B)
my pic I added is post face lift, not sure if its different
Just looked at the pic don't think mines got that hole, is there another way to take them out easily or does the headlight have to come out first?
It should have a small hole. Shame im not on my laptop as id do a pic for you
The pre face lift not the same as mine then Andy?
    5. 2
