Always Amazes Me
Bmw 116d 2011 her fault codes
My name 116d has a judder when accelerating, strong smell from exhaust and low mpg I plugged a diagnostic reader in and it came up with EGR codes, I have replaced my EGR valve, map sensor mafs sensor and breather hose but still experiencing the same issues plugged in reader again still says egr codes and then bank 1 lambda sensor so replaced that and still have the egr codes. any one have any idea what it could be as have sunk loads of money into it so far and don't want to keep doing so -
Misfire at 2000rpm
Hello, my 20 year old 3 series estate (E91) has 93,000 miles on the clock. There are no codes detected at a BMW specialist's garage but there is a slight but noticeable stutter on acceleration. It happens when the engine reaches 2000 rpm in all gears. The vanos solenoids have been replaced, a new fuel pump fitted, new ignition coils and spark plugs. All the injectors have been cleaned and tested. A smoke test for leaks has been done-none discovered. Can anyone think of any other checks that can be done without breaking the bank? -
X5 wanted
I have a 2003 for sale. email me if you like to chat. thank you John. -
Hi Ali Have you checked that the battery holding clamp is in place ? When the battery was changed was swapped like for like? Dave -
Hi Guys, I’m after a bit of advice here! I have changed the battery and now all of a sudden i’m getting the “Battery Restraint Malfunction” warning on the dashboard. When I go to clear the code and restart the engine the warning comes straight back on. Any ideas what to check first? Thanks in Advance. Ali
