Hi there guys.
I have a 2002 316ti with the 1.8 n42 engine. Does anyone know if the 2.0 engine will swap straight in without much messing. I did hear that they are the same engine but with different bore size. Any help would be great as my engine is about to give up and if I need a new engine then thois seems to be the way to go.
Double check the clutch/flywheel setup as they may be different...
Also, you may need the ECU with the engine !
    2. 4
    4. 0
