Hi there,
I have a BMW 316i, with 106,000 on the clock.
I need to top up the engine oil, although it only had oil put in during its last service in February, it appears to have run out - long running problem.
What is the best oil to use?
I do think I have a leak of some sort because it seems to run out of oil, but I cant see any on the floor once the cars moved- if anyone has any suggestions they'd be gratefully recieved!
Many thanks
Jennifer
hi jennifer.welcome to bmwoc.somebody will be along with some answers soon ;) ;)
It must be "Burning" it then !!
It's not advised, but with older engines I tend to put "Thicker" oil in... This usually slows down the inevitable...
I put Diesel engine oil in a petrol engine as it has tougher qualities !
  On 6/30/2011 at 6:40 PM, prestige interiors said:
I put recycled oil in my van I have a drum under it at night what comes out goes back in the morning :-)
Ahhh, Duckhams LOL
  • 1 year later...
5W30 is 'best' for your engine
In the future, please post a new thread as it will help others who have the same motor as you
Daz
  • 6 years later...
Expand
NO. Don't ever add the wrong oil type. Solve the problem instead: The 316 is renowned for valve stem oils seals going. They perish. Get them replaced then drop the oil and filter. Add fresh corect oil and new filter.
