E30 Engine Conversion 4 Pot To 6Pot, No Fuel/ignition Or Injection??
Have just carried out a conversion to a 1990 4 pot 1600cc to a 6 pot 2000cc.
Have the engine, g,box, 2000cc harness and ecu.
The fault is has no spark, fuel pump, or injectors pulsing. Its like the ecu isnt getting correct power ignition feeds so can power thoses electrical items, but ecu has many power supplies. Does anyone have a wiring diamgram so can check has correct supplies?
Also about 6inch away from the ecu connector on the 2000cc wiring harness it has x1 black 3 pin plug and x1 white 3 pin plug, do these do anything?
Is the front engine bay fuse box the same for both cars?
Thanks for any help, all be appreciated!!!
I'm afraid you may have missed a few electrical components...
Did you bring the loom with the relevent fusebox and relays (AND ECU) etc?
The loom was still attached to engine with the ecu. they said the fuse box is the same?
PM me your last five vin numbers and I will check the wiring diagram for it... Then compare it to the six potter !!
Sorry I couldn't get back to you, had a bit of a drama at the weekend :angry:
What caused the prob, if you don't mind me asking ?
    5. 2
