Just a quicky, is it ok to lower just the front of a car? I'm happy with the back but the front defo needs dropping abit so is it safe to do so or does it throw all the alignment out or something.
Cheers:)
It's fine, but not too much or it will look a chuff !!
Also you'll need to raise the headlamp beams...
Bear this in mind though... With the front-end stiffer/lower the rear WILL give way much easier under braking/cornering !
To get BMs sitting right its normally a 60/40 split (60 on the front) :) I did 40/40 and the front still sits way too high :( hopefully not for long tho :) coilovers here I come !!
      Mileage
      Mileage
      Mileage
    5. 4
    • Bubba jay earned a badge
