Can anyone help recently brought an x5 4.6is 2003 brought a new cradle etc and leads from bwm dealer for my iphone 3gs.fitted them and found 3 broken wires in the process under the centre arm rest reconnected them but nothing doesnt even charge or use signal through ariel.Then found two blown fuses to the right hand side of the boot area a 10amp and a 30 amp replaced them and then got telephone up on the computer screen.But still all i get is a red light on the computer and the message activate phone? Any ideas or advice please or has anyone got wiring diagram for the harness to the phone as all wires are either earth or nothing is this why its not even charging ?HELP!!!!!
Hi mate first off well done on your choice of x5 I have same as for phone I don't have the answer mine had blue tooth parrot fitted try doing a google search for wiring loom . Failing that I'm sure someone will have the answer on here
Regards Chris
It tells you the code on the unit under on coms pack in boot under 6 disc player if you have one there is a button in consul it took me a few times to sort mine if not sorry to say its down to BMW I think
... Or 0000
But if it's second hand then previous owner might have changed it !
Down to BMW i thinks you will need to get the unit in the boot locate pass code just a thought is the phone kit in the arm rest on a quick reease system there is a button at the rear of the kit to remove it
    4. 13
    5. 2
    • Mish earned a badge
    • Bmw90 jack earned a badge
