hi there can any1 help me i have a bmw 320i coupe and it has the doors with no pillars i have a slight problem with passenger door when close sometimes the window will not pop up back into place to secure it, can any1 help me with is there a sensor or anything that could do with being cleaned out or any other ideas thanks!!post-1609-0-12551500-1311072045_thumb.jp
Yeah i get that with mine now and again i just drop the window and then put it up again that usually sorts it :)
Usually happens if i drop all 4 in one go and then put 3 up except the drivers side, and its always drivers side that gets stuck :)
Yep I agree,reset the motor using the window button :) (cant remember how to do it tho,something about holding the button down and count to 5-10)
I struggle when counting :blink:
Let me help.....1,2,3,4,5,6,7,8,9,10 !!
I also struggle with pythagoras theorem :unsure:
Again I say...let me help
In mathematics, the Pythagorean theorem or Pythagoras' theorem is a relation in Euclidean geometry among the three sides of a right triangle (right-angled triangle). In terms of areas, it states:
In any right triangle, the area of the square whose side is the hypotenuse (the side opposite the right angle) is equal to the sum of the areas of the squares whose sides are the two legs (the two sides that meet at a right angle).
The theorem can be written as an equation relating the lengths of the sides a, b and c, often called the Pythagorean equation:[1]
where c represents the length of the hypotenuse, and a and b represent the lengths of the other two sides.
The Pythagorean theorem is named after the Greek mathematician Pythagoras, who by tradition is credited with its discovery and proof,[2][3] although it is often argued that knowledge of the theorem predates him. There is evidence that Babylonian mathematicians understood the formula, although there is little surviving evidence that they fitted it into a mathematical framework.[4][5]
The theorem is about both areas and lengths, or can be said to have both areal and metric interpretations.[6][7] Some proofs of the theorem are based on one interpretation, some upon the other, using both algebraic and geometric techniques.[8] The theorem can be generalized in various ways, including higher dimensional spaces, to spaces that are not Euclidean, to objects that are not right triangles, and indeed, to objects that are not triangles at all, but n-dimensional solids. The Pythagorean theorem has attracted interest outside mathematics as a symbol of mathematical abstruseness, mystique, or intellectual power; popular references in literature, plays, musicals, songs, stamps and cartoons abound.
HAHAHA Epic! :lol:
+1
Daz
Geek ;)
thanks for the help have tried reseting the motors by holding window button down but still hasnt really solved the problem will have to keep trying :( nice try snype :)
      X3 2.0 automatic
      Water leak at sharkfin aerial
    3. 7
    4. 13
    5. 13
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
    • jn1253 earned a badge
