been checking over the car tonite and come across a bust lower arm bushing on the nsf thats worn would this give me a steering wheel shake i know its probly a stupid question really :unsure: .
the car will drive in a straight line but the car is nervous and shackes at the steering wheel :(
There you go Phil... You found a prob !!
A BMW (any rear-wheel drive) car will suffer wobble with a worn front bush because of their "Toe-In"...
Front-wheel drive cars tend to have "Toe-out" for traction.
If you can afford it, get them ALL changed with Polymer bushes.
Find an independent German car part's dealer or Ebay like what I do :) Or.. http://www.eurocarparts.com/
cheers fellas , i sure i read it somewereabout 95+ m3 bushes were surrposed to be quite good better than 96+
how much do polybushes tend to be ? :unsure:
Im just about t purchase new wishbones with rear poly bushes to cure the same problem !!
Ebay all the way
had a look on ebay for the bushes the poly ones and they were only £40 quid which i didnt think was bad really , the rest of the wish bone all looks in tip top ,
