Just wondered if anyone had any thoughts on a couple of issues i've got with my 320d touring :unsure:
1st there's an intermittent drone from the back end but only happens really between 70-80 mph it's kind of a ummmmm ummmmmm sound but it's only when the wheels turn at a certain point as it's not constanly there, bearing perhaps :huh: ?
2nd I get a clunking/creaking noise from the front offside corner usually at low speed when braking and turning it sounds like somethings loose or rubber or bush has failed or could it be the caliper moving? sometimes it's quite bad and other times just a slight noise.
Any help would be appreciated as I want to sort theses out a.s.a.p so I can start to really enjoy the car and also my kids are in it all the time so don't want to have any safety issues.
Cheers :D
I think you already know the problem dude.
I'd say bearing and front bushes.
Not mega money to sort, but them rear hubs a a nightmare to get off.
Cheers mate defo sounds like a bearing on the back but I'm sure the front bushers were done for the mot it did have an advise for something on the front tho now I come to think of it it may be that.
You will be supprised how many bushes are down there mate.
Also drop links have a habit of going on these.
I've checked the MOT sheet and the anti roll bar pins/bushers should have been changed so maybe something just need tightening up after they were done, gonna get underneath tomorrow and have a look it's defo gotten worse today so need to sort it soon.
Ok I've been right uinder the car and can't find anything loose or worn so not a clue what it could be, the only thing I did notice was one of the rubbers on the wishbone had split abit but I don't think that'd cause the noise I'm getting, would it be worth me spraying everything with WD just in case it's something that's just abit dry and in need of a bit of lube, long shot I know but?
With regards to the noise on the rear I guess it's a bearing but gonna get the wheels re-balanced just incase it's that.
The rear "drone noise" may well be a bearing, you could drop the discs and have a look ! Or maybe tighten the shaft-nut a quarter !!
As for the front... Could be the strut mate...
Just some ideas pal :unsure:
Have a friend "bounce" the front-end while you hunt the noise !
Ive had those symptoms on pretty much, all my cars ive had.
Front end usually turned out to be drop-links had warn and once snapped o_0 and have had issues with shocks. As dabz said, 'bouncy! Bouncy!' :)
The rear just sounds like a dodgy bearing...
Daz
      Bmw x4 2015 angel eyes
      Steering lock query
    3. 4
      E66 730Ld with issues
    4. 0
      850i for sale no reserve
    • Mikeyladders earned a badge
      Reacting Well
    • Super Bmw earned a badge
    • drew lemke earned a badge
    • bpd1984 earned a badge
