Can any1 help the interiornlights works but the 2 side 1s wont, ive changed the bulbs and still no joy , do they run off separate fuse also the bulb in the boot that doesnt work after changing the bulb.
Daft question (1), where the newer bulbs of the correct (same) type.?.. Some cars use standard and some use canbus !
ill check it tomorrow but they wernt working with the old bulbs which to be honest looked ok.
