This Site Needs A Refurb
Register new battery
Hi, Have purchased a new exide battery which has not come with the 12 digit code. Does anyone know what i could enter to bypass this section. I am upgrading battery so detailes need to be entered. Using a Foxwell nt510 scanner. -
Non starter
Hi Dave,thank you for your reply,it was running before i got my hands on it🤣the car is not local to me so will probably have another go this Sat. But will try what you've suggested and many thanks! Will update the progress on this! Cheers Daryl
