What is the most common problem with your car?
Misfire at 2000rpm
On your advice I have left a message with Ash Motors North Wales. Many thanks again -
Misfire at 2000rpm
Noise
Noise
Hi i have BMW x1 f48 2018 in cold weather up to 10 deq two or three minutes after open the door of the car a noise appears does not matter if engine is on or still off the noise appears for 10 or 20 seconds and disappears I am attaching a recording to give you an idea what noise I mean. Glenbuck Ave 16.m4a Glenbuck Ave 16.m4a Glenbuck Ave 16.m4a
