came across a set of 2nd hand but new unused HR springs for the 320 . On checking the part numbers against a webb site they appeat to be the dight ones .http://www.motorsportworld.co.uk/framefix.asp?productcode=PS-120289&PID=1434002
It says which model they will fit including models fitted with the M Tecnic suspension which mine has .
In note 63 it says veicles fitted M Tech may drop less but there is a chance of getting a lot less than new .
Should I or should'nt I <_<
Gav not should or should'nt fit a kit . Do I risk getting these springs to find they are no shorter than what ever &#33;Removed&#33; length the M Technic springs are . All I managed to find out the shocks are the sames as in the Z3
From playing around with some cardboard 450/20 wouild seem right but if I go for those it will be budget springs
I brought 40 40 springs for mine, my rear is lower than yours quite a bit.
The front is lower too.
Your don't seem as high as min was before i lowered her, but is defiantly higher than mine now...
Ill find you a pic
hold on
Gav yer image is'nt showing but I have seen a pic of your 18's on .
Ok I will let the auction run its course and have a pop.
      Price
    5. 3
    • Jlou17 earned a badge
    • JCDenton earned a badge
    • Luke330 earned a badge
