Hello again club, I have a problem with my central locking system on my 2002 x5. 90,000 miles. its 4.6 si. The central locks wont operate with the key, but they will work with the internal switch. I cant lock or open the doors with the key from outside either which makes me think that the key is not the problem. Can anyone assist me please. Thanks.
Have you tried re-programming the fob to the system?
No, I have not tried to reprogram the key & have no idea how to do this. Thanks for your advice.
Harry
You have been a great help with my problem, I will try this out tomorrow. Again thanks.
Harry
Good luck... And, if it fails, don't panic... It could take a few tries !!!
BTW, thanks for the "Rep" point B)
Today I tried to use the method that you kindly directed me to. Something happened as when I released the lock button the rear windows lowered & the sun roof opened. But no joy with the central locks, also now they wont operate from inside switch.
Thanks, Harry
At some point in the procedure it worked as you must've held the unlock button too long and that activates full-open ! Keep trying...
      Bmw 116d 2011 her fault codes
      Misfire at 2000rpm
      Noise
      Noise
    5. 3
      Misfire at 2000rpm
    • welshchy earned a badge
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
