Looking To Buy A 3.0D Help Needed
9
Thanks Dave & Stu, this is a big help, thanks. I have the original key which starts the car. The locking doesn't work, but I'm not bothered. I took it to a copy shop. The guy couldn't get a reading from the transponder. (That's the immobiliser, right?) So I said to him to make me a copy anyway. 25 quid. The copy operates the doors and the ignition but not the starter. So I now have a key with a transponder chip *SEE PHOTO* (I assume the red bit) and I need to copy the code from the original key and copy it into the new one. I did see a thing online but I don't know if it'll copy. https://www.amazon.es/-/en/gp/product/B0DY7VCTQZ/ref=ox_sc_act_title_1?smid=A18I26BYARIXXP&psc=1 -
hi Dave, I had a look there and if its there I couldn't find it, the only other place it seems to suggest is to do with the BC button on the indicator lever but I have tried that as well and no joy, it may be that there is some sort of procedure which has to be followed in the right order but until now I am at a loss. cheers Paneuro. -
9
9
Hi Norrimac. the key you had cut, did they programme the key to the ignition? They would have had to read the key from your car and remove the dme unit and circuit board from your car. the chip in the key is a small black rectangular thing about the size of a rice grain… this is what needs programming. what key reader was used? If the ignition key works, then the reader doesn’t. The key reader I use is actually an AK90… I can send you a link if you are tech savvy.
