Severe Interior Detailing
Morning Mish If they are listed in realoem then they should fit one point with DMF replacement make sure new flywheel bolts are included and fitted. My neighbour has an Uprated 330i had a new DMF clutch etc and within 3months was suffering similar symptoms to a failing DMF the garage he used hadn't used new bolts but tried to convince him it was his uprated engine and his driving style that caused premature failure they were telling him he needed a new DMF. A fiddle but we got his car high enough on some hired Jack ramps and when we pulled the box the DMF was actually loose 8 new DMF bolts about £25 and Torqueing them correctly fixed his problem that was 2 years ago now with no issue since. Dave -
17
Good morning Dave True, the one I got ad 79k, full BMW service history and I had to replace almost all gaskets, o rings, hoses, abs sensors, seals, and I still don’t have a fault free car. Although I have just serviced the car, it looks that I should replace the oil sensor just to be on the safe side, I am using the car for family holidays so the last thing I want is to be stranded. Thank you for the support. Very much appreciated!! Take care Dimitri- 1
2008/09 520d
Morning Martin Welcome to the Forum Try Disconnecting the Battery for at least 30 mins (a Dealer trick to clear faults) Neg first Dave
