Is there somewhere i can run the power cable from under the bonnet to inside the car (e36 318)?
Iv had a look but i cant seem to find anywhere.
Yes, there are some spare rubber grommets on the bulk-head, or chase-back thru the throttle cable !!
Look behind the engine my friend... There should be a few bungs, either blank or with a bit of loom thru...You can use the blank one by piercing it and passing your wires through to the internal footwell !
Generally speaking, the majority of BMW batteries are in the boot with the jack, behind a pull down trim panel... But there is a Juicy main live "Jump" terminal under the bonnet :)
    • Alan520d earned a badge
    • Mama1809 earned a badge
    • First Bima earned a badge
