Winter Wheels And Tyres
Water leak at sharkfin aerial
Morning Billy When was the car last serviced ? The symptoms you describe could be due to an air or vacuum leak, old hoses seals and vacuum lines can start to crack when cold they are stiff and don't leak (as much) when hot and flexible you see the issue developing. Your OBD Scanner needs to be BMW capable a standard scanner will only see critical functions. Dave
