Bmw 730Ld Se Glow Plugs
Noise
Sorry, I can’t open any files… but mine will ding if the temperature is below 5’ as a warning of ice. Maybe it’s set to 10’ in yours?? just a thought -
Noise
Hi i have BMW x1 f48 2018 in cold weather up to 10 deq two or three minutes after open the door of the car a noise appears does not matter if engine is on or still off the noise appears for 10 or 20 seconds and disappears I am attaching a recording to give you an idea what noise I mean. Glenbuck Ave 16.m4a Glenbuck Ave 16.m4a Glenbuck Ave 16.m4a -
Misfire at 2000rpm
Thank you, Dave, this is just the sort of advice that I'm after and you have summed up the symptom perfectly. I've just been into Halliwell Jones (BMW North Wales) and they're looking for £156 per hour for a diagnosis! So any advice is welcome. -
Bmw 116d 2011 her fault codes
Hi Chynna Welcome to the Forum What Diagnostic Reader did you use although many readers will give a code they will be general rather than specific A BMW capable Diagnostic reader will normally not just give a code it will also give a description of the fault helping in diagnosing a fault Dave -
2010 X1 Water leak on passenger side footwell
Hi Raymond Welcome to the Forum Sun Roof Drains are a known culprit doesnt take much fror them to get clogged Dave
