Music
Bmw 116d 2011 her fault codes
Misfire at 2000rpm
Misfire at 2000rpm
Noise
Sorry, I can’t open any files… but mine will ding if the temperature is below 5’ as a warning of ice. Maybe it’s set to 10’ in yours?? just a thought
