Hi Pete, Found this on the web, hope it helps
Ok.. without having your x5 on a diagnostic machine to check for stored fault codes... your most likely problem here is cas trouble.... crank shaft sensor... These do fail - and their function in life is to pick up a signal from the crankshaft - and this then triggers the ignition side and the fuel side... without that signal , the vehicle has zero chance of running. As you say the problem is intermittent - then this is definitely your most likely cause.... It will not send a signal to the ecu (computer) telling the fuel system to operate - hence no fuel/pressure......( and the ign system to
Hope this helped, keep us informed. Alan
thanks alot mate id read that somewhere already , i just diont get if its that why it doesnt start everytime now , unless i crack a injector pipe and leave it for about a min then tighten up and it will go , im thinking of taking the plunge on a "fuel rail pressure sensor" it'd be nice if i could test mine but can't find any test data... anyone know?
cheers Again
Pete
Hi Pete, I could only suggest to have it checked on the diagnostic equipment, unless someone else can come up with an idea, good luck. Alan
    5. 2
