Hi guys
I have got an E36 318is Coupe on a 1996 P-plate.
The fuse for the central locking had blown so i replaced it but since replacing it the passenger side door glass keeps moving up and down slightly .....(as if you were opening and shutting the door). Its does this every few minutes so i took the fuse back out
There is a fault with the central locking aswell .... it will not operate the passanger door
Is this a common fault or any idea's of a problem or will both of the above be related ?
Thanks
      Alloy wheels
    • SteveC51 earned a badge
    • Dan_C earned a badge
