I would say yes !
But, could be dependant on engine size :unsure:
Its a 1.9 engine,the problem is the abs light is on and some times it goes off ,its like it has a mind of its own.Im very tempted to remove the abs as long as the speedo doesnt run of it.
Your Speedometer runs off the gearbox in all cases... The ABS will have issues if either -
The inside of the discs are soiled/rusted...
Sensor failure...
Fluid levels or air in the system...
OBD reset after work has been done has not been done...
The ABS Unit is faulty...
BTW You DO have ABS... Check the above 1st and get back to me with your findings...
HTH Daz
Just out of interest, what is the difference in tread depths of your front and rear tires.
My fronts were replaced last January, but the rears hung on till they were down to the legal limit.
The abs/asc did not like the huge difference in tread depths and threw up abs warnings and skid warnings.
All gone now it has new tires all round.
John.
About 70% all round mate i dont no a great deal about the motor all i no is the bloke liked painting things silver lol
Even sensors ? :lol:
P reg should have come with ABS, I'm sure it was that year.
May have just missed it if its an early model.
  • 4 weeks later...
if it turns out expensive to fix im gonna look at removing the abs
I wouldn't do that Richard :blink:
The light doesnt come on all the time either im hoping its just some thing simple mate im gonna have alook over it tomorrow
If you have an ABS light that lights up then (stating the obvious) you have ABS... How does the brake pedal feel? When was the fluid last changed? Did you have a look at what I mentioned way back in this Topic?
DAZ
      Price
    5. 3
    • Jlou17 earned a badge
    • JCDenton earned a badge
    • Luke330 earned a badge
