hi folks im new to site but need help.When it rains i get water running in down the drivers side windscreen pillar and dripping on to carpet and dash any advice to cure problem i have looked at sunroof drains and gutters both fine
Welcome Robert, Have you checked the rubber seals, where the water is leaking in from, there should be water marks, how long has it been leaking?
hi mate thanks i have not checked seals but that will be next job thanks.Are they easy to repair/replace will sunroof need realigning?
Aarrrhhh Arr, Arrrrrhhh (Bugger, Talk Like a Pirate was in October, Grrrr)...
Take down your head lining, there will be a pipe from the drain hole in the sunroof going down the piller, check this ain't come loose mate.
      Water leak at sharkfin aerial
    • Driverbus70 earned a badge
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
