Just a message to say hi guys. Im Mark, I've got an E36 323ci AC Schnitzer. Finally got around to joining. Look forward to chatting (and hopefully getting to some meets)
Has your motor had the Schnitzer treatment, or just a couple of badges? What's the spec? BTW, we love piccies !!!
Oh yes, full AC Schnitzer treatment. Just sorting some pics I took a couple of months ago as its in the spray shop at the mo having any slight marks that I've picked up recently removed. How much do you guys know about window seals?
Cheers pal. I'll tell you what it is, the rear windscreen and two rear vent windows seals look very perished. I've been told by somebody that it's not the seals that you can see but just plastic or rubber fillers to lose the gap from the body work to the window? Do you know how true this is?
It was the seals, and the rubber compound used... They failed to maintain their shape, causing seepage and internal dampness... This was corrected as you may have read...
There is a fix - Knife along the lower edge of the seal and fill with sealant or screen-bond - both flexible, this will push-out the seals to re-create their purpose...
Or better still, replace them with later model seals...
My quick-fix is cheaper, though... !!!
Brilliant, that's great. I'll give that a try. I'll put some pics of the perishing on with the pics of the car if that's ok to see what you think?? Cheers Dabsy
Yeah, pics first before you try my kwik-fix eh?
      Water leak at sharkfin aerial
    • Driverbus70 earned a badge
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
