keep getting clunking from under car when going over uneven ground.
did front drop links still the same ,looked at track rods wishbones ,sturt mounts all fine
does any one no what this could be
thanks steve
Wow not going to be an easy one to find, Does the clunking sound like metal on metal? It`s well worth putting the car onto axle stands then go around all the joins with a crow bar, the slightest play can make the strangest noise. Is it coming from the front or back of the car, if it’s the middle it will be a center bearing!
Exhaust ? Propshaft ?? the list is endless really,get underneith and just give everything a good yank/poke/bash :)
sounds like its coming from rear putting it on axle stands at weekend
as am going to renew diff oil have a good look around then
cheers steve
My E39 had a similar noise. Turned out to be the Shocks where knackered
Drop links...doubt it but maybe bearings...but you would prob feel bearings more than hear them.
Broken spring?
Yes, had this on my Megane, tried everything, done my head in ended up a broken spring.
springs are all ok bushes and shocks checked bearings and flexi disc form gearbox to shaft are fine'
did front drop links about 6wks ago ,goning to do back ones tomorrow just in case
How about trying something simpler like, wheel nuts, bearing tightness? Maybe look at the shocker rods for seapage/damage? Just a thought because you seem to be trying everything else!
Could even be a caliper/pad/handbrake issue ?!
Its quite mad that how small and seemingly pointless they are, they can make a big horrible noise when knackered
Glad its sorted mate.
      Water leak at sharkfin aerial
    • Driverbus70 earned a badge
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
