14Th April Meet In Kent
Water leak at sharkfin aerial
3.0i starter motor
I stand corrected…. It wasn’t the starter. I could hear it clicking so checked the battery, amps were about 10… new battery and fired straight up…. So much for Halfords and yuasa battery testing! ….now to the next issue…
