New Bmw Owner
Rear View mirror has come off windscreen screen
Never experienced this before but the rear view mirror has seemingly parted company from the windscreen. It seems that a round metal disk should be glued in some way to the windscreen and then the plastic housing can be put back. Any experience/instruction out there on how best to go about reattaching this? -
18
BMW 318i boot locked can’t get into
Hi did you solve problem that your boot locked and no power ?? Also me got same problem 318i 2011 unfortunately i disconnected battery and closed the boot . Is there any easy solution ??- bmw
- bmw 3 series
(and 4 more)
Tagged with:
Register new battery
Morning Steve Where did you get the Battery ? they should have the code. When you say " upgrading " the battery be careful fitting an overrated battery can cause as many issues as a failing one. The correct battery for your car I believe is either a 90ah or 92ah AGM type also check the CCA (ColdCranking Amps) matches I have never used Foxwell to register a Battery only ISTA/INPA but I don't recall needing a 12 digit code just confirmation of the Battery type Have you checked online for any Video help there is a lot out there these days Dave -
Hi, Have purchased a new exide battery which has not come with the 12 digit code. Does anyone know what i could enter to bypass this section. I am upgrading battery so detailes need to be entered. Using a Foxwell nt510 scanner. -
Morning Kieran Welcome to the Forum This is a new problem, I would start with the power supply where have you taken it from ? If you haven't already I would check a wiring diagram for both models to see where the power was arranged in the M4 and check whether that supply is available in the 140 model. Then check www.realoem.com to see if there are repair/replacement looms available. Your description sounds like a relay is tripping in the power feed Good luck with finding the issue let us know how yoy get on Dave
