hi all any ideas on this problem
my car has just started flashing up check on dash and on comp it says brake light circuit check i have checked the brake lights and they are both workin so dont understand
any help welcome
Could be any of your bulbs mate, check them all
Ones usually missed are fogs and reverse lights
Also check all front lights.
Have you changed a bulb recently?
If your car was younger I would guarantee this was the problem...but I'll say I'm 70% sure mate
Check the "common" earths in the boot area, mine were loose !!
Also, a failing battery/alternator will throw errors in the dash as BMW's demand quality power from both !!
      Water leak at sharkfin aerial
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
    • Karlos70 earned a badge
