Hi Guys,
Since i bought my 328 it has used oil.. not much if you drive it normally more if you give it a good thrashin.. I have looked every where and there is no oil stains or patches.
There is no smoke at the back so it cant really be burning it off.
The only thing i can think ov is when i launch it, or its under harsh breaking, its coming out of the cap..
What do u think
mine likes a drink when hammered,if just nippin around it sips it.
Perhaps its just a common thing... Any one else have the same issue.... if so could we update the common faults thread with it
I very very much doubt it due to how old it is, but does yours have a Nikasil engine fitted?
If it aint leaking it, its burning it
I don't think the M52 had nikasil liners.
Maybe the engine-breathing needs a good clean out!
Early m52 engines did have this problem as that’s what killed the 2.5 lump in my e39 when it was 3 months old, however BMW knew a problem was there and was pretty quick to recall!not many iffy engines are left Dabsy Breather system is a good shout!
Thanks Ian, mainly affects V8 and V12 although there is a little "Tell-Tale" if it is a nikasil unit...
