The White Russian
Hello there. What steering wheel fluid do i add to an E39 2003 Petrol? I'm based in UK -
Good afternoon, I am new to the forum after purchasing my 2015 BMW 520d touring last week. Loving the car so far however I noticed that it has a gutted DPF. I contacted BMW to see if the EGR cooler recall had been done and they advised it’s never been in for the recall. I have booked the car in next month for this recall. My concern, my car has a gutted DPF (only noticed yesterday) and I wondered if getting the EGR cooler recall done would cause me running issues ? Last thing I want to do is create issues. Has anyone else put their BMW for this recall with a gutted DPF and did you have any issues afterwards ? -
filter change recomendations
OK will look to adopt that advice. Oil filter does get changed out annually but will look to the air filter also. Good idea on hoovering the pollen filters though. -
Thanks for your input. I checked the the DC Voltage with a meter on either side of the fuses (152 and 182) on top ,so I know the fuses are good I also checked the relay 'on the bench' and it's functioning too. Maybe the car needs a reset with a BMW Diagnostics kit as there is still an icon on the dashboard which will not clear?
