Young Driver Insurance
Parking sensor problems
Hi Ken Depending what OBD reader your using will either give Generic codes or if it is a fully BMW capable one then you should get better results (I use BMW ISTA/INPA) First I would check near the front fuse panel on the side behind the trim you should find a Multiple Earth point (BMW love these) check it carefully they were a well known source of problems on the E53 and E70. If you have a wiring diagram it may help idntify which pins to check continuity on. As far as I am aware the JBE with integrated PDC is just that it may mean a complete unit which will need coding to the chassis. Unless of course someone like ECU Testing (Derby I think) can fix it but that may put the car off the road for a few days Or as my daughter once told me "you don't need all that stuff Dad there is a Thud when your to close" 🤣 Dave -
Great thank you Dave. I assume if I have continuity from this connector to the wiring behind the bumper then there is an issue with the JBE itself. Do you know if there is a module or anything on the JBE that could be in fault or am I looking at a complete replacement unit? -
Hi, I have a problem with my 2011 X5 front parking sensors. I have used an OBD reader to check the failure codes and it appears all 4 front sensors have a ground or open circuit fault. I have checked the wiring harness for the front sensors and the main plug behind the bumper and all seem fine with no damage. I assume this must be the PDC module as it’s all the front not the odd sensor. But I cannot find it anywhere. can any one help please? -
My son is getting creative
Update! … bonnet and boot sourced and awaiting delivery from a very nice guy who breaks BMWs… Tim at bmw classic spares in Northampton. once they are on, I’ll set about polishing the whole car and try to hide the side scratches. It’ll be like a new un! -
9
Bmw angel eyes
Hi Ben Without carrying out a full test on each TMS it is difficult to say. I would check the internet for any test criteria then start with the good one note the results then test the faulty one to compare. All I found on the TIS is it is likely to be the LED's (2 of them) how simple it is to change them I have no idea. As an Example I recently had a failed Halo/Parking lamp on my E70 checked ISTA says remove cover 3 screws remove 2 further screws and the lamp is out Ha Ha Ha. What i discovered in WIS was a note that says remove Headlamp from the car to access the screws. Dave
