Hi Guys, HELP my 53 plate 320cd was started to whoosh when you change gear mainly at slow speed to much noise when middle range, sounds like coming from front end.
Mate said it sound like air leak when the turbo has no work to do but he is a plumber. Split hose, blocked filter, turbo, (kids making the whoosh noise).
Any ideas or any one had the same problem? Thanks Tony.
Well every BMW ive had and ive had a couple, have at some point had to have the thrust barring changed on the gear box.... that makes that sort ov noise as well Bmw do say they will last a while but perhaps its worth having it checked..
Ben
You would probably "feel" a failing thrust -bearing thru the clutch pedal.
      Misfire at 2000rpm
      Bmw 116d 2011 her fault codes
    3. 4
      Misfire at 2000rpm
      Noise
      Noise
    • welshchy earned a badge
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
