Yes it's easy, look on eBay for the replace ment units for around £30 don't bother with just the bulbs for a few quid as they are rubbish.
Thanks guys for your replies.
Cheers for the offer Christian but I replaced them a couple weeks back.
Purchased some H8 LEDs for £70, so not cheap and not totally convinced about the result to be honest! The inner ring (which the bulb fits directly into) is fine but there doesn't seem to be enough light making it's way to the outer ring, so in daylight the oter rings appear to be barely illuminated. While this is better than having the yellowish illumination of the standard halogen bulbs, when you see a later BMW with the factory fit xenon/led angel eyes they look considerably better than the after-market LED option. They look ok at night though, as the dipped-beam xenon is in the outer ring, so that either helps to make the ring look illuminated or draws your attention away from the fact that it's not very well illuminated.
  • 4 weeks later...
Ok, I've decided that the LEDs aren't that great! I'm sure i've seen some of the H8 "complete" Xenon kits for sale somewhere, anybody have any recommendations? Cheers! :)
  • 5 weeks later...
Hi guys I have a 55 plate with angle eyes thats running on a H6W units. Where can I get an relacement LED units from as I can't find any on ebay.
Thanks in advance
  • 4 weeks later...
Hi Mate,
Type this number into eBay search and have a look - 160762865388
They are rated 6000K - pretty bright angel eyes LED replacement bulbs.
I use these and am very pleased with the result.
      3.0i starter motor
    4. 0
      Bmw x1 2012 won't start
    5. 6
      X3 2.0 automatic
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
    • Karlos70 earned a badge
