At MOT time last year I got a warning on both off side and near side lower (rear) suspension arm rubber bushes deteriorated but not resulting in excessive movement... Do you think they will need doing this year? Its done about 8000miles
Ta
Caz
According to my MOT tester deterioration is not a failure providing there is minimal up and down movement, sideways is not really counted unless severe. hope this is helpful
If I dont do them though it'll fail wont it if they need doing.. wasnt sure if its something that gets worse with wear or over time?
Hi, They do get worse over time but how much is very debatable, the parts are cheap the labour is not. But its a life that you may be risking one day. I am meticulous and I am still here at nearly 67 years old and still a Beemer fan.....
I agree, especially if you intend to keep her ;)
Thanks for the replies.. think I will just get them done, been thinking about changing the car but I could just buy a whole new load of probs so will stick with the beemer for now
Caz, poly bushes are worth a thought, the rear arm body mount bushes cost me £40 from powerflex and though a swine to get the old bushes out, the poly's went in perfectly. And of course they will last forever....
  On 2/26/2012 at 6:12 PM, kirby williams said:
£230 not expensive lol yeh right
http://www.ebay.co.u...=item35ada1ea2e
Not so bad in my opinion... A FULL SET of standard ones from BMW would hit you for £130+, Poly's last three-times longer...
Would stiffen the ride a touch too.
Well £209 later and I've had them done! Just the standard bushes, didnt have time to sort poly ones out.. I hope it passes the MOT tomorrow, or my flexible friend will be well and truly flexed!!
It'll fly thru.... Money well spent I think ;)
Excellent, roll-on next MOT pass eh?
Not for another 12 months Dabs!! Do the rules change soon where by I'll have to sort the airbag light by next one?
Depends how nice your local garage bloke is ;)
      Alloy wheels
    • Dan_C earned a badge
    • Gouden earned a badge
    • Markc earned a badge
    • Neil Stokes earned a badge
    • Mish earned a badge
