TBH, the majority of BMW's were "Belled" ! What shape key-fob(s) do you have?
No... It does have Central locking...
Your fob is the 3 button identical to mine...
The bottom-left button is Unlock, bottom-right should be boot release... I suspect the boot-motor or the wiring to it, maybe a fuse :unsure:
Ahhh, that may be the search fuction where it puts the h/lights on in a car park to find it (as it were) !
I'll be there in ten minutes !! Hahahahaha :P
(Merged this back on topic for you) !
The pics are a little blurred but looks like you found the issue !
Will the nylon holder twist enough for the rod to attach? If it will, maybe wrap an elastic-band around it !!
just removed the motor and found that the part that which the rod fits into was laying on the inside boot pannel so may need a quick fix of glue to see if that holds untill i can afford a new motor
I will go try it now lol is this how they usually get fixed?
thanks
No :huh:
Does the motor buzz when you press lock/unlock? If not, check wiring first before you start spending your beer-money on a new motor !
its all connected proper and it moves back n forward when i press the the lock/unlock button. I just removed it and it seems a piece has snapped off it. I will upload a picture as i can be quite confusing.
Deffo linkage if motor works matey !! Good find ;)
BTW, super-glue won't hold it !
But motor WORKS, don't buy another... Just botch the linkage, it'll be hidden behind trim anyway !!
Don't be silly mate... This is why I'm here :P
Maybe bend the rod-end enough and throw some DUCT-TAPE around it to complement your super-glue !
OR... Acquire some tube and clamp together?
I am an "Old-Skool" Fixer... Saves money and it's not Rocket-Science :D
fingers crossed (&) its fixed lol now all i need to do is:
locate alarm if one is fitted.
get door clips for to put doorcard back on
get a wing
fix the pipe that keeps blowing off if i accelerate too hard (vacuum) possibley jublie clip it on??
front wiper motor needed ASAP
things i would like to do is:
get alloys ASAP
tint windows
get it all sanded down and rust treated
resprayed in black to make it look fresh
lower it
cant think of anything else but will start a progress thread in time maybe later.
Thanks again Dabsy
