Hi, every one, Anyone know how long doe's a clutch change, thrust bearing etc take on a 320i take as my garage will match a quote, waiting with bated breath.......... Thanks
if it all comes apart and you have done it before with the proper tools, aka ramp-gear box jack, cup of tea 2-3 hours
Thanks Ian, BMW quote 3 3/4 hours which seems excessive, my local garage said the same so call it 4 hours to fit the clutch plate, thrust bearing and oil seals. total cost £241 seems OK to me against main dealer charges. Unless anyone knows different?
Sounds fine to be honest, Time is a little excessive but the price is right. the clutch kit will be about £120 from my guess work.
      X3 2.0 automatic
      Water leak at sharkfin aerial
    3. 7
    4. 13
    5. 13
    • Backmarker earned a badge
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
