Club Flyers, Help Needed!
Bmw x1 2012 won't start
X3 2.0 automatic
X3 2.0 automatic
Water leak at sharkfin aerial
7
As I understand the wiring diagrams and operation Item 9 on the thermostat housing is the sensor which sends its signal to the ECU for interpretation with information from the map sensor. Information from item 12 (1st drawing ) is also used to provide average temp across the cooling system. As far as I am aware the Thermostst is independent of the sensors and operated by expanding wax material internally
