help smoke coming from drivers side of engine look like it is coming from side and back of engine and some oil :( just poped to B&Q came back and noticed the smoke coming from under bonnet any ideas guys :(
Smoke or steam?
Smoke = oil leak dropping onto exhaust.
Steam = water...
Be careful though, it could be a short that is burning the wiring.
Run her from cold and watch with bonnet up !
Maybe let her cool and place your hand behind the head to see if it leaks from there, otherwise it could be sump gasket leaking onto exhaust !!
Is there a puddle when stood?
Without being there I would initially guess a crank or cam seal failure...
Let us know what makes yer hand wet LOL
hi its not water def oil and smells of oil burning had a feel found some oil at back and side of engine but not much i take it for another drive and it did not do it very strange but i can see small drip from underneath
had a good look to day i can see it on the exhaust running down but cant see where it is coming from :(
hi its a 4.4 52 reg could be im getting oil round the oil filler cap wipe it off and it comes back at first i thought i did not put cap on properly
New cap or cap-seal. It'll run crap with a poor oil-filler cap.
I'm a poet and didn't know it !
oil leak was rocker cover gasket all sorted now but got car back and temp control panel has gone from Celsius to Fahrenheit any ideas how to change back
      3.0i starter motor
    4. 0
      Bmw x1 2012 won't start
    5. 6
      X3 2.0 automatic
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
    • Karlos70 earned a badge
